Originally Posted By MrSixpack
1966 Chrysler 300 with a 383.
Just restored the ac compressor with new rubber seals and gaskets.
Filled it up to day with the help of my friend and ac expert(not expert on old car ac´s)
It is leak free and seems to be fine.
But it´s not blow any cold air, the inlet is pipe is cold and the outlet pipe is hot.
He thought it´s a valve problem?
What could it be??
Thanks.
As in water valve or expansion valve? Gauge pressures will tell you if it's an expansion valve problem.
Tim
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
