The formula as I've used it:
Percentage of Front Roll Bias: Front Roll Couple / (Front Roll Couple + Rear Roll Couple)
Front Roll Couple = (Torsion bar wheel rate * 2) + rear sway bar wheel rate
Rear Roll Couple = (Leaf Spring wheel rate * 2) + rear sway bar wheel rate
This is a great thread, but it looks like there is a typo in the formula. I'm not real sure, but it looks odd to me, so I thought I'd ask.
In the Front Roll Couple formula, it says to add the REAR sway bar wheel rate.
That's supposed to be, add the FRONT sway bar wheel rate, correct?
Tav
