Quote: I agree with Mr_P_Body See my signature link photos... I welded the bracket in front and is a bit of a hassle going up and over as it's a pretty snug fit. Would have been better with bracket behind the plate..
if you weld the plate in the front its a pain to do
but if you pass a long bolt througth the frame rail its only one bolt per side to do
I did mine so you use the whole frame rail to hold the moter in place, then just welding the bracket on a thin metal rail on top
