Looks good so far but you don't need the front brackets. There really isn't very much force on those brackets. The weight of the engine keeps it in place for the most part. Even with 600 ft-lbs of torque the bolts only have to resist about 150 lbs of shear force each on the driver's side. That is nothing for a bolt that size to handle.
