The amount of lobe lift you can run depends on where the oil
galley intersects the lifter bores, base circle of the cam and
style of lifter.
Galley to lifter bore varies greatly, block to block so xxx lobe
lift with xxx lifter is not going to consistantly work on every
block. Like most fun things about building engines.......you
have to check first.
