i built this new cam on my old software. after computing it looked like it would be an improvement. however my software is fubar right now.
when the cam grinder/cam shaft core builder kicked it back.. i want to see if i can tweek these last cam numbers to a profile that will not be soo difficult to grind or source.
we where sort of going after the dwell cams but with a solid roller.
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured [image][/image]
