If installed correctly they won't wad up, every one i have changed out never had a wrinkle in them. If installed correctly , having the tire desoaped, is that a word? [ cleaned and dry ] then use lots of tire talc to keep the tube from binding you'll have no problem.
OK then - have you ever seen one ripped? I saw a really nice 68 Cuda almost eat a wall and there was no evidence as to why, until he got home and decided to check the tube.
