poorboy---thanks-----after staring at the pictures awhile i decided my problem was i was trying to keep the belt tensioner---once i pulled that off i used that tang on the block to hinge the alternator---i deleted the rear pulley on the water pump----just need to bend the swinging? adjuster strap and will attach it to the front on the tang instead of the rear of the tang.
