Throw in the 140's...make sure the bolt to bolt is correct on only 1" of preload if their to far extended out of range the 140's are too stiff...but will work...if the bolt to bolt is too close together then their too light(not likely)....get your ride height as close to level as possible...set your bottom bar level or 5 max nose down...top bar 10 degrees and then plot it out...try to hit that 44-47 and 5.5-6.5 up and let her FLY !!!!....now the shock settings will need to be approx 4-6 full stiff on compression and 3-6 full stiff on rebound.Then sneek up on it...make one adjustment at a time...yes your TNT time is limited...Bill...it's gonna take time to get it dialed in...there is no other magic bullet to change that...passes...passes....passes!
