I might make a suggestion, clean all of the suspension points to make sure they arent binding. The 140 will be to stiff but try them since you have them. This stuff isnt theory its math, the one thing that I dont know on your car is the angle of the shock to calculate that in ... the closer you get to 45*, the closer you get to doubling the spring pressure
