Originally Posted By dogdays
Supercuda, you forgot that the transistor has to switch off and on in 3 degrees of rotation in order to have 42 degrees closed time or dwell.
R.
None of which affects how many times per second the transistor switches, just how quickly it has to do it.
I think you forgot there are 360 degrees in one revolution.
Remember each cylinder fires once for every TWO revolutions (720 degrees vice 360 degrees).
They say there are no such thing as a stupid question.
They say there is always the exception that proves the rule.
Don't be the exception.
