Originally Posted By sr4440
look at your output fitting coming out of the barrel valve, you should see a steel ball with a spring holding it against its seat. That is your idle check valve. they will work without it, but setting the idle is tricky.
Joe
Yes it does have that in the fitting..also I just pulled things apart to check ..barrel valve has a 86 jet 37 nozzles 70 jet in by pass ..
