Are you sure the barrel valve isn't too rich? Are you using the shut off to lean it out when you idle it? I had the same issue with the oil when I started running injection. My issue was all from not leaning it out when idling to get heat in the thing. Once I started getting the oil hot enough to get the moisture and alky out of it no more problems.
