I don't get the storage problem with a 2 post remarks. Aren't you suppose to leave a car on a 2 post? I have used my 2 car garage with 3 cars in it for years. The only advantage of a 4 post that I can see is you have a big shelve to pile more crap.
Two post all the way!
Four post if you mostly use it to store you car. (ONLY because of ease of just driving up onto ramps) you can store on a two post too.
The Ramcharger will be spending a lot of time on the 4 post as I need to box the frame for strength, just like in the picture below. After it will move on its own I will be using the lift for servicing the fleet. Another reason for the 4 post is that I live in earthquake country and I really don't need to store anything up high. My '64 Polara had its wheels off and was resting on four super duty jack stands when we had the Nisqually Quake and I expected it to be on the ground when I got home, but it was still on the stands.
