The Mustang rotors use the SAME bearings with a slightly different spacing. From everything that I have seen it takes a spacer in the Mustang rotor to fit the Mopar spindle. Take a close look at all the parts that come with the SSBC kit. In the end, you might find the SSBC kit will not cost much more than finding all the original K-H parts and rebuilding them.
