Yes both are 46re trans. What I mean by that is around mid year 2001 and later they started to use a 5 pin neutral safety switch instead of the older 3 pin.
They should both have the eight wire plug on the drivers side that points up as thats for the gov press sensor , gov solenoid , trans fluid temp , lock-up and overdrive. The only ones I remember with a 5 pin connector at the NSS instead of the 3 pin switch was the ones that used a Range Sensor for the electronic reading in the dash. But its been a long time since I worked on one and my memeory may be a little fuzzy on it. I would need to look at the wiring diagram to be sure. Ron
