I don't look at the "free play" pedal adjustment or TOB clearance spec recommendations from the mfg,I start with the airgap of the clutch disc, see what RAM specs the air gap at?, if no specs are available, a BorgBeck cover is usually .040 to no more than .050 max, after the airgap spec is achieved and the clutch engagement and shifting into reverse and 1st gear encounter no clash, then look at what you have for free pedal play, and TOB clearances,and adjust those values without affecting the clutch airgap spec
Trying to set the clutch with pedal specs might result in you over centering the clutch cover on release resulting in a damaged cover, or warped cover ring
