Ok, well all this makes me feel better. I have not heard of a car as heavy as mine using anything below 300. So if the 250 still seem like there to much, ill go even lower. Thanks guys
What length springs are you buys EDIT With the bottom adjuster set at 1" up from the bottom your shaft should be where you want it... if its just a little off move it with the adjuster... more than 1" the spring is wrong
