it has to have a steel sleeve and you must have missed it or else it will eat itself out of housing and home.
and if it doesn't do that, once galvanic corrosion sets in, the bolt will weld itself to the bushing, making a real treat to remove. i have learned many new words over the years dealing with this issue. it's not so or too bad when there is more than .020-.030 clearance between the bolt shank and the bushing hole, but that just accelerates the hole wear. when you get the slop out of the bushing [as it should be to be effective], that allows the two dissimilar metals to corrode together locking them solid. then the fun begins. and even using a sleeve, anti-seize or high pressure grease is a must for best performance.
![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
