I'm using an innovate LC-1 with an in-dash gauge. It's relatively cheap compared to the LM-1, however the LC-1 does not datalog if that's important to you.
Is there any reason you want to run two sensors? Are you jetting one side of the carb different from the next or running a cross ram intake of some kind?
