am I opening up pandoras box !!
not at all! I have an innovate LM1 but I ain't hooked it up yet (bought it used from a CL character so hopefully it is still OK). I have the 8MM bung needing to be welded in. iirc there are some round gauge ones that you can permanently mount in the dash that are pretty accurate. I'm looking forward to the responses also
