Those look like Pro Systems build sheets,Call Patrick with the carb order # and specs on what you will be using it on. He will usually get you pretty close if possible. I did it with a dom that I bought from a member here and he was more than happy to help. Now have 2 of his dominators and an SV1.Jim
64 Dodge Coronet 440. In progress
1998. Dodge Avenger. 8.35@165. 4400 DA
250” Neil and Parks Slip Joint. 7.36@183.
4600 DA
242" Mullis Dragster. 6.90@ 200mph
