During a car cruise, my Challenger just shut off and wouldn't restart. After fiddling with it for awhile, it finally restarted. I made it about 100' and it shut off again. This time it restarted right way. I was only a few block away from home so I was able to get it there. When I went to exit the car, my foot brushed the steering column connector. At that same moment, the engine hiccupped for s split second. I grabbed the connector and gave it a wiggle. The car died. Make sure your connections are tight!
