Originally Posted By Paul_Fancsali
Just one thing I ran into on a 2.5 take the cap and totor off and lift the plastic sensor plate and check to see if the plastic parts on main shaft of dist are still there and functioning I had to JB weld mine back together as mine was doing the very same thing { Timing was moving all over the place }
X2
The shutter wheel in the dist is a known for coming loose from the plastic base.
