Factory air equipped B-bodies from 1966 thru 1970 The water valve IS mounted to the firewall, with the backside of the valve actually protruding thru the firewall itself into the interior of the car. All valves from 1966 thru 1969(not sure of the 1970 valves ) ARE cable controlled.
This valve is designed to mount to the passenger side inner fender ala E-body and 71 up B-body. And regardless of what someone says or states is NOT correct for anything 1969 b-body in any way shape or form
This appears to be the correct style valve for 1969
The correct valve mounts to the firewall with 3 of these screws
Thanks Bill.
That is what I was finally beginning to figure out for myseld but glad you confirmed it.
Now the question is, are there any replacement valves out there for this?
