No to the full dish, use a D-shaped dish or reverse dome so if you now or later use a head with a squish area it can work.
www.theoldone.comR.
A full dish works great with my friends LS turbo,I have Edl victor heads now.
0
If your starting from scratch and you can get the comp low enough where you want it, absolutely the reverse dome or the D dish.
Sure the full dish works, but the other has been proven to work so much better. Better more efficient combustion chamber, less chance of detonation, more HP etc. So why wouldn't you? Do it, IMO, it cant be that much more expensive.
