Porter67 - I hear what you're saying but rero parts can be made exactly like NOS if the desire is there to do so. Parts are made from engineering drawings. If you have the correct measurements you can make it correct. Many of the parts lend themselves to be reversed engineered to exact specifications, again, if the desire is there to do so. So, either you draw it up right and create that correct part or you decide you are going to go the easy way, the cheap way, or whatever way and make it close, but in the end, incorrect. To me, if I was going to spend the time and energy to create a reproduction part, I would make it correct as opposed to incorrect.
