bore gauge does read on + side of 0 when inserted in rod bearing. Reads .0061, so either im reading gauge wrong or its inaccurate. Meatured bearig again with snap gauge and get 2.202 and rod jounal is 2.199. Ill try a different dial on the bore gauge tomorrow and see what happens.
So you get three with a snap gauge and six one with a dial bot gauge?? Hmmmm. I'm more comfortable with your numbers from the snap gauge right now.
Weird.
Just because you think it won't make it true. Horsepower is KING. To dispute this is stupid. C. Alston
