good luck pulling those studs! use caution. I cant get mine out. gotta live with exhaust leak until I pull heads
He said they were resealed already so I don`t think removing them will be a problem. I helicoiled two of my stud holes on my 340 and never had a issue. The factory studs seem to have a better taper on them where they meet the head then aftermarket studs, that why I was asking if he used OE or not.
