John, you might want to do a search of the forums for the past two months. Another member bought the tank and was complaining that he couldn't fit the higher volume pump (from Tanks !!) through the opening. Had to butcher the tank to make it fit. If the standard pump works for your application then I guess you're golden!
Keep us posted ... I'd like to know how that FItech unit as well as everything else performs.
Thanks Stanton I'll check that out.
I bought the 600HP FiTech unit so I'll need the bigger fuel supply.
