Originally Posted By rebel
i did it to this block as well.
That is so cool!!!
I can understand why you want to do this trick. I built a 460 Ford motor for a truck swap and one of the retainer rings that restricts the cup in a hydraulic lifter came out and ended up jammed in the oil pump gears. Fortunately the oil pump drive shaft broke and the engine stopped sick
I dodged a bullet there.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
