Have you determined if you actually "need" the offset pushrod seats? If not, I'm pretty sure you can use amc lifters with mopar link bars for pushrod oiling, or switch to 87019 lifters(for the offset without pushrod oiling) and run the spray bar valve covers.
If you put restrictors in the lifters, the feed holes should be pretty small.
