I have a 63 330 I recently removed the rear from. work It has the 2 piece axles with the locknut. Is there any reason I can't save it and order a set of axles from Dr. Diff to convert it to a 65 design? I noticed the backing plates were different but if using the newer backing plates and drums (65 up)I can't see any reason this shouldn't work? shruggy
Thx...
...FAFO...
