I use my left foot to scrub-just a squeeze on the brake pedal while staying in the throttle- and then roll off the throttle and roll into the brake past the stripe. I have found that with the four link, when you drop the nose hard you get a slightly spooky wander to the right that isn't there when you just ease off the throttle and ease into the brakes.
My car doesn't do that at all. My chassis drives like your on rails.
Left foot braker here as well, even on the street.
Karma has no menu. You get served what you deserve.
