I have always set the final number with the engine running to allow for any variation due to worn bushings etc. If something is really worn it obviously needs rebuilding.
And to the OP, you are aware that closing the gap increases the dwell right ??? Also make sure your meter is on the appropriate scale IE: 4, 6, 0r 8 cyl.
beer
