you may have 2 different problems.
pegging gauges are probably still the limiter.
killing them could also be a bad ground when you turn on the parking lights because they have no path to complete the circuit.
to peg the gauges, you must have more than 5 volts going to it.
I would pull out the limiter and bench test it before you burn out the gauges.
