For small primer work to seal bare metal spots buy a disposable Preval sprayer at the hardware store and use it to apply whatever primer system you want. Easy to use with very little overspray.
Reducer used in the good two part paint and primers will lift any rattle can paint that doesn't have a hardner in it. Then you have to strip it all back down and start over.
