If it were mine I would change that oil very early to get the metal from the break in out of the engine.
Thats what you have filters for. Plus if there is metal floating around in a new motor there is a problem. All new cars are driven with a new motor there is no difference from reman to new. In some cases the reman may be cleaner.It all has to do with the assembler and if he is particular on cleanliness.
