Originally Posted By ahy
You are good... it is not easy to get lead to stick to steel and be somewhat level.
My choice on beat up metal or welds is neither. I use a first fill of epoxy. JB weld or PC7. It sticks very well to steel... much better than bondo and is waterproof. I use bondo for final smoothing.
jb weld is not flexible it can crack or pop out if used on the body of a car that has a lot of flex. not the best choice for bodywork for sure.
