curious, I have the msd blaster 2 coil, is it worth going to the ecoils for this conversion
Does the blaster 2 require a resister, if so you need a coil that takes 12v to delete resister
not sure if the msd blaster 2 requires a resistor...
it depends on what ECU. the Blaster 2 is a full 12v coil. one example is if using the MP orange box or aftermarket equivelent, then yes, you would want the ballast.
