I run a standard 180 stat, and an electric adjustable cooling fan control. Engine warms up quickly to 180 and then I can adjust the fan to come on where ever I want. I also have a switch mounted under the dash so I can run the fan continuously if I want. Gives me full control to run the engine temp where ever I want. Of course you have to have enough rad ( and fan )to do this. If I want to run at 190, I set the controller so the fan comes on at 190. Temp usually oscillates about 10 degrees as the fan kicks on and off.
How did this thread get so long? Your correct answer is right here in the 2nd reply.
