If you have a water pump housing in front of the timing cover, locate the spot on the outside of the timing cover where the button contacts, then mix up a blob of epoxy and sandwich it between the pump housing and the timing cover with some wax paper to allow future separation. The pump housing will reinforce the tin timing cover.
