Originally Posted By AndyF
If you're running a Dominator carb then the M1 4500 will make more power. If you're running a 4150 carb then it is a tossup. I think the M1 4500 makes more power but it might depend on the combo.
Good luck finding a M1 4500. I don't think they are making them anymore so you have to find one in stock somewhere.
Thank's Andy, I know how you are using a victor to dyno with but was curious about the M1, a buddy of mine has a dom flange M1 that I can use if I want.
I tested both intakes. The M1 made better power so I switched to the M1.
sounds like I really cannot go wrong with ether one unless there was a big difference between them.
Light travels faster than the speed of sound,,,this is why some people seem bright untill you hear them speak.
