So John, which PTK module below would be best for a '68 VB? I have an old lockup VB that has the upper one that I was going to steal.
The lower one, the limit valve won't function in a '68.
Also, is it true that if you decrease the space between the kickdown valve and the throttle pressure cam that it will downshift at a higher "closed throttle" condition? If so, is this a good or bad thing?
Not unless you make it real tight. There is no advantage.
The INTERNET, the MISinformation superhighway
