Hmmm interesting. Well, the 650 horse is a rough guess because I'm going to use the new trick flow 240 head for the big blocks, and a 615/621 lift, 260/264 @.050 duration solid flat tappet from Hughes, at either 10.51 or 11-1 compression. I was reading a forum the other day on here and they had a 470 stroker with the same heads, not sure on cam, but 10.5-1 on pump gas and it made 675 horse @ 6,100 rpm. Im most likely going to use a factory forged crank unless a cast crank will hold up. Id like a forged one though.
