I don't know the size of the resistor, but painless used one too. it is already wired in. I clipped the wiring with it still intact.
I will double check but it seems correct.
383 man, this is not quite stock anymore.
the engine and injectors and throttle body are stock.
it is using gm sensors for temp the stock tps, but the distributor has been modified with that shutter wheel and sensor.
it was running an aftermarket efi setup and I am replacing it with another efi setup, just trying to figure out why it won't get a signal.
