hi , I have same setup in my 340, the cable has to be wound left handed. speedo cable is right handed, and will unwind.only place I seen so far is Pegasus, 1 800 688 6946. might try stewart warner, they are making that tach again. good luck. the dist has a round end with a blade , tach has .104 sq end.
