One major reason for replacing the plugs may be so they don't "grow" attached to the heads. Lots of wrenches have seen broken off plugs when they try to remove them at up around 100 thousand miles. Even worse are the Fords that have a habit of blowing the threads out of the heads if the plugs aren't removed and lubed every once in awhile.
July 19th should be "Drive Like Rockford Day". R.I.P. Jimmie.
