I feel the best thing to use is a deep offset wheel that you can add spacers to to find your correct spacing. With a Hotchkis setup the biggest wheel I can fit is a 18x10.5 as it hits the bumpsteer spacers in the fronts. Without the bumpsteer spacers you could possibly run a 18x11 in the front. I used 2 Enkei PF01's with tires mounted on them so I could drop the car on the ground on its full weight and set ride height as well.
73 `Cuda
Instagram: @rylispro
YouTube: RylisPro
www.rylispro.com
925-214-9192
