If I copy the motor mount provisions off a 68 or 69 B Body HEMI K member and locate them on the exact same spots on an E Body K frame after I shave off the regular V8 mounts, would I have a K frame that locates the HEMI in the correct spot for an E Body?????
I am asking this because I heard sometime that the actual steel HEMI motor mounts (the left and right units that bolt on the block and then to the insulators) were different between years and bodystyles. I always thought they were all the same. Im not 100% sure if this is true though!!!
So having said that, I was wondering if the K frame HEMI motor mount provisions on the 68-69 and 70-71 E Body HEMI K frames would be basically the same or would they vary?
Im trying to make me a repro E Body HEMI K frame using a regular V8 E Body K frame and a 68/69 B Body HEMI K frame as a template to copy from....
